Model.midsurface_new_plate#
Model.midsurface_new_plate(collection, plate_type, use_base_surfaces, reserved)#
The function creates a new plate from the surfaces on the input mark. The plate component, for visualizing the newly created plate and containing copies of the original model’s surfaces, is also created. If the surfaces on the input mark previously had different plate attributes, their copies in the temporary plate components are deleted.
If the base surface information is set to be taken into account, the function will also do a preliminary check whether the given set of surfaces includes any base surfaces or not. If there is any base surface present and the intended merged plate type is “planar” or “sweep”, the function will not do anything.
Parameters:
  • collection (Collection) – The collection containing the surface entities.
  • plate_type (int) –
    This parameter specifies the type of merged plate to create. Valid values are:
    0 - Create plate of type “auto”
    1 - Create plate of type “planar”
    2 - Create plate of type “offset”
    3 - Create plate of type “sweep”
  • use_base_surfaces (int) –
    This specifies whether the user-defined base surfaces will be taken into account when displaying the plate information. Valid values are:
    0 - Base surface information is not taken into account. There is no restriction as to which surfaces can be used to merge into a single plate.
    1 - Base surface information is taken into account. If the input collection contains a base surface, the function will not do anything in cases when the intended plate type is “planar” or “sweep”.
  • reserved (int) – Reserved for future use. Must be set to 0.
Example#
Set the surfaces with IDs 5 - 7 to become a new plate of type offset , without include a check for the input mark to contain base surfaces#
import hm
import hm.entities as ent
model = hm.Model()
surface_collection = hm.Collection(model, ent.Surface, [5, 6, 7])
model.midsurface_new_plate(
    collection=surface_collection, plate_type=2, use_base_surfaces=0, reserved=0
