Model.hm_count#
- Model.hm_count(entity_name, selection_flag, config_num=0, type_num=0)#
Counts the entities in the database.
- Parameters:
entity_name (hwString) – The name of entity to be counted. This parameter may be set to any of the entities in the database.
selection_flag (hwString) – Indicates which entities are to be counted. Valid values are all and displayed.
config_num (int) – The configuration number of the entities to be counted. This parameter is used only if <entity type> is set to elements or loads. If set to zero, the entities are counted regardless of their configuration.
type_num (int) – The type number of the entities to be counted. This parameter is used only if
entity_name="elements". If set to zero, all of the entities are counted regardless of their type.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:count (int)
Example#
Count all the component entities that exist in the database#import hm import hm.entities as ent model = hm.Model() _,result=model.hm_count( entity_name="Component", selection_flag="all" ) print("Count: ", result.count)
Note
In the template function @count(), if the displayed option is selected (active) on the export data panel, the value returned by @count() includes only those entities that are currently displayed. In the Tcl/Tk function hm_count(), this has to be indicated explicitly using the argument selection_flag.
