Model.hm_comparegettransformationcount#
- Model.hm_comparegettransformationcount()#
Returns the number of transformations found. This must be preceded by a call to a relevant hm_compareentities function.
Multiple transformations can be found by
Model.hm_compareentitiesrecursive(),Model.hm_compareentitiesrotate()andModel.hm_compareentitiestranslate(). Other hm_compareentities functions only find a single transformation between source and target entities.- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:numberOfTransformations (int)
Example#
Find the number of transformations for the recursive comparison of surfs with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surf1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surf2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesrecursive( source_surfaces=surf1, target_surfaces=surf2, tolerance=0.1, result_type=2, review_results=False, ) _, result = model.hm_comparegettransformationcount() num_transformations = result.numberOfTransformations print("num_transformations", num_transformations) model.hm_compareend()
