Model.hm_findclosestpointonsurface#
- Model.hm_findclosestpointonsurface(x, y, z, surface)#
For a given point on a surface, this function returns the closest other point on that same surface:
xs ys zs dist
where xs, ys and zs are the coordinates of the point on the surface closest to input point, and dist is the distance between the original and projected points.
- Parameters:
x (double) – The x coordinate of the known point.
y (double) – The y coordinate of the known point.
z (double) – The z coordinate of the known point.
surface (Entity) – The object describing the surface entity.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:pointCoordinates (numpy.ndarray)
distance (double)
Example#
Find the point closest to a point with coordinates ( 2676 , -737 , 605 ) and located on surface with ID 7#import hm import hm.entities as ent model = hm.Model() _ , result = model.hm_findclosestpointonsurface( x=2676, y=-737, z=605, surface=ent.Surface(model, 7) ) print("pointCoordinates", result.pointCoordinates) print("distance", result.distance)
