Model.curvemathexternalfilter#
Model.curvemathexternalfilter(outputcurve, xbased, filter, parameter)#
Runs an external filter on a curve.
Parameters:
  • outputcurve (hwString) – The name of the curve to be generated.
  • xbased (int) –
    1 - If the function should operate on the x coordinate.
    0 - If the function should operate on the y coordinate.
  • filter (hwString) – The name of the filter.
  • parameter (hwString) – The user-defined parameters for the filter.
