Model.hm_ce_getdefaultconnectorcontrolfromconfig#
- Model.hm_ce_getdefaultconnectorcontrolfromconfig(solver, style, feconfig)#
Returns the connector control default name and ID for an FE config.
- Parameters:
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:connectorControlName (str)
connectorControlID (int)
Examples#
Get the connector control default for solver nastran , style spot , and FE config “ rbe3 ( load transfer ) “#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_ce_getdefaultconnectorcontrolfromconfig( solver="nastran, style="spot", feconfig="rbe3 (load transfer)" ) ctrl_info = [result.connectorControlName, result.connectorControlID] print("Connector Control Info: ", ctrl_info)
