Model.createfbdgroupfortraceplot#
- Model.createfbdgroupfortraceplot(name, node_ids, entType, num_cuts, path_dir, userDir=hwTriple(0.0, 0.0, 0.0), sys_def='Global', system=Entity(), sys_ref_dir=hwTriple(0.0, 0.0, 0.0))#
Creates a freebodygroup entity, used for FBD trace plots. Options can be provided in any order.
- Parameters:
name (hwString) – The name of the freebodygroup to create.
node_ids (EntityList) – The entity node list for the trace path, given in sequence. A minimum number of 2 nodes are required.
entType (EntityFullType) – The element entity type.
num_cuts (int) – The number of cuts between each sequential node in
node_ids. Ifnum_cuts=0then sections are only created at the nodes.path_dir (int) –
0 - User direction
1 - Trace path direction
userDir (hwTriple) – When
path_dir=0, this is a triple double defining the direction vector.sys_def (hwString) – The system definition. Valid values are “Global”, “Direction based” and “User defined”.
system (Entity) – The system entity.
sys_ref_dir (hwTriple) – The reference direction defined as a triple double defining the direction vector.
Example#
Create a freebodygroup named test with no cuts , a user direction , and system with ID 1#import hm import hm.entities as ent model = hm.Model() model.createfbdgroupfortraceplot( name="test", node_ids=[813, 664], entType=ent.Element, num_cuts=0, path_dir=0, userDir=[0.803557, 0.595228, 0.000000], sys_def="User defined", system=ent.System(model,1) )
Create a freebodygroup named test with 4 cuts , a trace path direction , and no system#import hm import hm.entities as ent model = hm.Model() model.createfbdgroupfortraceplot( name="test", node_ids=[813, 664], entType=ent.Element, num_cuts=4, path_dir=1, )
