Model.blockwallfindintersect#
- Model.blockwallfindintersect(blockname, wallname, type)#
Intersects one- and two-dimensional finite elements with cells in a finite difference block.
- Parameters:
blockname (hwString) – The name of the block.
wallname (hwString) – The name of the wall into which cells are to be inserted.
type (Collection) – The collection containing the entities.
Example#
Intersect elements with IDs 1-10 in block with name “block1”#import hm import hm.entities as ent model = hm.Model() elems = hm.Collection(model, ent.Element, list(range(1, 11))) model.blockwallfindintersect(blockname="block1", wallname="wall1", type=elems)
Note
The ID of any cell, knowing the (i,j,k) location, may be found by the formula (i*divj*divk)+(j*divk)+k, where divj and divk are the number of divisions in the j and k directions, respectively.
Note
Display must be in planar mode for this function to work, and only one plane can be displayed. The displayed plane is the plane that is filled.
