Model.solid_untrim#
- Model.solid_untrim(collection, force)#
Untrims solids by removing surfaces that separate them.
- Parameters:
collection (Collection) – The collection containing the surface entities to untrim.
force (int) –
0 - Only surfaces that separate solids (solid on both sides) are removed.
1 - Surfaces are deleted even if there is no solid on one of the sides. Normally this causes solid destruction but it may be useful as a way to remove solid cavities.
Example#
Untrimme the surface with ID 100#import hm import hm.entities as ent model = hm.Model() model.solid_untrim(collection=hm.Collection(model, ent.Surface, [100]), force=0)
