Model.isolateentitybymark#
- Model.isolateentitybymark(collection_set, elements_off=False, geometry_off=False, showcomps=False)#
Turns on the display of a collection of entities and turns off the display of all others of the same type.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities with a display state.
elements_off (bool) – This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
geometry_off (bool) – This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
showcomps (bool) – This indicates that components in which elements/geometry are referred will also be shown when you show elements/geometry. If not provided, only specified elements/geometry are shown.
Examples#
Isolate geometry and elements for components with IDs 1 - 3#import hm import hm.entities as ent model = hm.Model() comp_collection = hm.Collection(model, ent.Component,[1,2,3]) collection_set = hm.CollectionSet(model) collection_set.set(comp_collection) model.isolateentitybymark(collection_set=collection_set)
Isolate all components and load collectors , consider only elements#import hm import hm.entities as ent model = hm.Model() comp_collection = hm.Collection(model, ent.Component) loadcols_collection = hm.Collection(model,ent.Loadcol) collection_set = hm.CollectionSet(model) collection_set.set(comp_collection) collection_set.set(loadcols_collection) model.isolateentitybymark(collection_set=collection_set,geometry_off=True)
