Model.attributeupdateintarray2delementmark#
- Model.attributeupdateintarray2delementmark(collection, identifier, solver, status, behavior, row, col, value)#
Updates one element of an attribute of type integer array.
- Parameters:
collection (Collection) – The collection containing the entities that owns the attribute.
identifier (int) – The identifier of the attribute.
solver (int) – The solver number of the attribute.
status (int) – The status of the attribute.
behavior (int) – The behavior of the attribute.
row (int) – The row number the value to be changed resides in (first row is zero).
col (int) – The column number the value to be changed resides in (first column is zero).
value (int) – The new value of the 2D array element.
Example#
Update the load collectors with ID 48 , 82 in * PEAKOUT_CID_ARRAY2D * dataname (identifier=2311) in 2nd row , 2nd column in Optistruct profile by set attribute to 3#import hm import hm.entities as ent model = hm.Model() # Finding the PEAKOUT_CID_ARRAY2D identifier using the hm_attributeidentifier function _, r = model.hm_attributeidentifier( entity_type=ent.Loadcol, entity_id=48, attribute_name_or_id="PEAKOUT_CID_ARRAY2D" ) # Setting the dataname model.attributeupdateintarray2delementmark( collection=hm.Collection(model, ent.Loadcol, [82, 48]), identifier=r.id, solver=1, status=2, behavior=0, row=1, col=1, value=2, )
