Model.loadcreatewithsystemonentity_curve#
- Model.loadcreatewithsystemonentity_curve(collection, config, type, comp1, comp2, comp3, comp4, comp5, comp6, system_entity, transform_flag, x_loc, y_loc, z_loc, curve_id, x_scale)#
Creates loads, defined in a local coordinate system, with magnitudes defined by a curve.
- Parameters:
collection (Collection) – The collection containing the entities. Valid entity types are nodes, points, lines, elements, surfaces, components and sets.
config (int) –
The config of the load to create. Valid options are:
1 - Force
2 - Moment
3 - Constraint
5 - Temperature
6 - Nodal Flux
8 - Velocity
9 - Acceleration
type (int) – Solver-dependent type of the specified config.
comp1 (double) – The component of the load being applied. For all configs except constraints (
config=3), this component represents the load in x-direction.comp2 (double) – The component of the load being applied. For all configs except constraints (
config=3), this component represents the load in y-direction.comp3 (double) – The component of the load being applied. For all configs except constraints (
config=3), this component represents the load in z-direction.comp4 (double) – The component of the load being applied. Applicable only for constraints (
config=3).comp5 (double) – The component of the load being applied. Applicable only for constraints (
config=3).comp6 (double) –
config=3).Note
For constraints, all of the components are active unless they are set equal to -999999.0. All of the other components of the constraints are active in the respective directions.
For pressures, to create a pressure which is normal to the element, set all components to zero.
system (Entity) – The coordinate system to be used.
transformflag (int) –
Indicates which system supplies component values. Valid options are:
0 - If the component values are supplied in the global coordinate system.
1 - If the component values are supplied in the local coordinate system.
x_loc (double) – For loads on components or sets, this is the display location where the graphical image for the load is drawn in x-direction.
y_loc (double) – For loads on components or sets, this is the display location where the graphical image for the load is drawn in y-direction.
z_loc (double) –
For loads on components or sets, this is the display location where the graphical image for the load is drawn in z-direction.
Note
If
x_loc,y_loc,z_locare 999999.0, or more than one entity is selected, the display location is automatically generated.curve_id (unsigned int) – The ID of the curve defining the magnitude of the load.
x_scale (double) – A scale factor applied to the x-axis (or time-axis) of the curve.
Example#
Apply a force of magnitude 10.0, use curve with ID 11 along the x axis of system with ID 4 to nodes with ID 5 and 25#import hm import hm.entities as ent model = hm.Model() node_collection = hm.Collection(model, ent.Node, [5, 25]) model.loadcreatewithsystemonentity_curve( collection=node_collection, config=1, type=1, comp1=10.0, comp2=0.0, comp3=0.0, comp4=0.0, comp5=0.0, comp6=0.0, system_entity=ent.System(model,4), transform_flag=1, x_loc=999999, y_loc=999999, z_loc=999999, curve_id=11, x_scale=1.0, )
