Model.morphmapedgestoplaneoffset#
- Model.morphmapedgestoplaneoffset(user_mark_id, plane_normal, plane_base, use_symmetry, use_constraints, project, vector, number_of_mid_handles, offset)#
Projects the handles on the marked morph volume edges to the specified plane along the specified vector, plane normal, or normal to any attached shell elements (unusual for morph volume edges).
- Parameters:
user_mark_id (int) – The ID of the user mark containing the morph edges. Valid values are 0-3.
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
use_symmetry (int) –
0 - Do not use symmetry links
1 - Use symmetry links
use_constraints (int) –
0 - Do not use constraints
1 - Use constraints
project (int) –
0 or 10 - Project along vector defined by vector_id
1 or 11 - Project normal to surfaces
2 or 12 - Project normal to attached shell elements
If
offsetis non-zero, the offset will be measured from the closest point on the plane for values of 0, 1 and 2. The offset will be measured along the projection vector or normal for values of 10, 11, and 12.vector (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
number_of_mid_handles (int) –
-1 - Do not change the handles on the edges
0 - 5 - Update the number of mid-handles on the edges to this number
offset (double) –
The distance to offset nodes from the target.
The offset will be measured from the closest point on the plane for values of
projectof 0, 1, and 2.The offset will be measured along the projection vector normal for values of
projectof 10, 11, and 12.
Examples#
Map edges on user mark 0 to a plane along a vector with offset of 1.2 and leaving the handles unchanged#import hm import hm.entities as ent model = hm.Model() model.morphmanageedgemark(edge_id=0, user_mark_id=0, mode=3) model.morphmanageedgemark(edge_id=2, user_mark_id=0, mode=1) model.morphmanageedgemark(edge_id=4, user_mark_id=0, mode=1) model.morphmapedgestoplaneoffset( user_mark_id=0, plane_normal=[1.0, 0.0, 0.0], plane_normal_base=[1.0, 0.0, 0.0], use_symmetry=1, use_constraints=1, project=0, vector=[1.0, 0.0, 0.0], number_of_mid_handles=-1, offset=1.2, ) model.morphmanageedgemark(edge_id=0, user_mark_id=0, mode=3)
Map edges on user mark 1 to a plane along the plane normal with 3 mid-handles per edge#import hm import hm.entities as ent model = hm.Model() model.morphmanageedgemark(edge_id=0, user_mark_id=1, mode=3) model.morphmanageedgemark(edge_id=2, user_mark_id=1, mode=1) model.morphmanageedgemark(edge_id=4, user_mark_id=1, mode=1) model.morphmapedgestoplaneoffset( user_mark_id=1, plane_normal=[1.0, 0.0, 0.0], plane_normal_base=[1.0, 0.0, 0.0], use_symmetry=1, use_constraints=1, project=1, vector=[1.0, 0.0, 0.0], number_of_mid_handles=3, offset=0.0, ) model.morphmanageedgemark(edge_id=0, user_mark_id=1, mode=3)
