Model.correctoverflowsubmodelentityids#
Model.correctoverflowsubmodelentityids(submodel_type, id, entity_type, option, renum_option, pool_id)#
Corrects an entity ID range overflow for a submodel.
Parameters:
  • submodel_type (hwString) – Submodel type to correct the ID range overflow for a submodel. Valid values are “includes” and “includefiles”
  • id (unsigned int) – The ID of the submodel.
  • entity_type (hwString) –
    The type of entity to correct the overflow for.
    0 - All entity types in the submodel are considered.
  • option (hwString) –
    0 - Overflow IDs
    1 - Underflow IDs
    2 - Both overflow IDs (default)
  • renum_option (hwString) –
    1 - Compact and fit (default)
    2 - Move after max
    3 - Move before min
    4 - Insert in gaps
    5 - Offset and fit (not yet supported)
  • pool_id (unsigned int) – The optional ID of the solver pool.
Examples#
Correct components in include file 1 with “both” overflow option and using “move after max” renumber option#
import hm
import hm.entities as ent
model = hm.Model()
model.correctoverflowsubmodelentityids(
    submodel_type="includes",
    id=1,
    entity_type="comps",
    option=2,
    renum_option=2,
    pool_id=0,
Correct all entities in include file 1 with “both” overflow option and using “move after max” renumber option#
import hm
model = hm.Model()
    id=1,
    entity_type="0",
    option="2",
    renum_option="2",
    pool_id="0",
