Model.rigidlinkinodecalandcreate#
- Model.rigidlinkinodecalandcreate(node_collection1, set_id, attach_set_option, dof)#
Creates a rigidlink elem by calculating the independent node based on selection of dependent nodes. Location of independent nodes will be at the geometric center of dependent nodes.
- Parameters:
node_collection1 (Collection) – The collection containing the dependent nodes.
set_id (unsigned int) – The ID of the set that contains dependent nodes. Set type should be of nodes.
attach_set_option (int) –
Options for attaching a set to rigidlink:
0 - Set entity will not be created when multiple dependent nodes are selected.
1 - Set entity will be created when multiple dependent nodes are selected and then assigned to rigidlink.
dof (hwBoolList) – The degrees of freedom for which the element is active (list of six Boolean values representing the 1-6 DoFs).
Example#
Create a rigidlink element by select only dependent nodes ID 1 , 2 , 3 , and 4 without the attach set option#import hm import hm.entities as ent model = hm.Model() model.rigidlinkbycollector( node_collection1=hm.Collection(model,ent.Node,[1,2,3,4]), set_id=0, attach_set_option=0, dof=[True,True,True,True,True,True] )
Create a rigidlink element by select only dependent nodes with the attach set option#import hm import hm.entities as ent model = hm.Model() model.rigidlinkbycollector( node_collection1=hm.Collection(model,ent.Node,[1,2,3,4]), set_id=0, attach_set_option=1, dof=[True,True,True,True,True,True] )
Create a rigidlink element by select only dependent node set with ID 2 with the attach set option#import hm import hm.entities as ent model = hm.Model() model.rigidlinkbycollector( node_collection1=hm.Collection(model,ent.Node,populate=False), set_id=2, attach_set_option=1, dof=[True,True,True,True,True,True] )
