Model.hm_getmodelcheckdisplaynames#
- Model.hm_getmodelcheckdisplaynames(check_type="ALL", entity_type=EntityFullType()))#
Returns check display names.
- Parameters:
check_type (hwString) – The type of check, ERROR, WARNING, INFO or ALL. If blank, then all checks of all types are returned.
entity_type (EntityFullType) – The type of entity. If ALL, then checks for all entity types in the profile are returned.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:displayNames (list of strings)
Examples#
Get the check names for all check and entity types#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckdisplaynames() print("displayNames:", result.displayNames)
or#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckdisplaynames(check_type="ALL") print("displayNames:", result.displayNames)
Get the check names for ERROR for material entities#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckdisplaynames(check_type="ERROR", entity_type=ent.Material) print("displayNames:", result.displayNames)
