Model.hm_getshelloverlapinfo#
- Model.hm_getshelloverlapinfo(source_collection, target_collection, maxproximitydistance)#
Returns information regarding proximity overlap between a selection of components or elements.
- Parameters:
source_collection (Collection) – The collection containing the source entities. Currently supported for components and elements.
target_collection (Collection) – The collection containing the target entities. Currently supported for components and elements.
maxproximitydistance (double) – Maximum proximity distance below which the overlap is calculated.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:proximityArea (double) - The proximity overlap area
proximityVolume (double) - The proximity overlap volume
maxProximityDistance (double) - The maximum proximity distance
minProximityDistance (double) - The minimum proximity distance
boundingBoxMinimumCoordinates (numpy.ndarray) - The minimum bounding box’s corner coordinates
boundingBoxMaximumCoordinates (numpy.ndarray) - The maximum bounding box’s corner coordinates
orientedBoxOrigin (numpy.ndarray) - The bounding box’s origin
orientedBoxXVector (numpy.ndarray) - The bounding box’s x-vector from origin
orientedBoxYVector (numpy.ndarray) - The bounding box’s y-vector from origin
orientedBoxZVector (numpy.ndarray) - The bounding box’s z-vector from origin
Example#
Get overlap information between component with ID 7100314 and component with ID 7100361 for a proximity distance of 5.0#import hm import hm.entities as ent model = hm.Model() comp_collection_1 = hm.Collection(model, ent.Component, [7100314]) comp_collection_2 = hm.Collection(model, ent.Component, [7100361]) _, result = model.hm_getshelloverlapinfo( source_collection=comp_collection_1, target_collection=comp_collection_2, maxproximitydistance=5.0, ) print("The proximity overlap area:", result.proximityArea) print("The proximity overlap volume:", result.proximityVolume) print("The maximum proximity distance:", result.maxProximityDistance) print("The minimum proximity distance:", result.minProximityDistance) print( "The minimum bounding box's corner coordinates:", result.boundingBoxMinimumCoordinates, ) print( "The maximum bounding box's corner coordinates:", result.boundingBoxMaximumCoordinates, ) print("The bounding box's origin:", result.orientedBoxOrigin) print("The bounding box's x-vector from origin ", result.orientedBoxXVector) print("The bounding box's y-vector from origin:", result.orientedBoxYVector) print("The proximity overlap area:", result.orientedBoxZVector) print("The bounding box's z-vector from origin:", result.proximityArea)
