Model.adaptive_wrapper_preview#
Model.adaptive_wrapper_preview(num_cavities, display_rep=0)#
In case of a cavity mesh, this function can be used to preview cavities which are detected by the adaptive wrap mesher. For each cavity, a unique component is created which holds the shell elements defining the cavity.
This function must be called after Model.adaptive_wrapper_build().
Parameters:
  • num_cavities (int) – The number of largest cavities to display. If 0 or not defined, then display all cavities.
  • display_rep (int) – Reserved for future development.
Example#
Usage of the adaptive_wrapper_build functions#
import hm
import hm.entities as ent
model = hm.Model()
# Initialization of wrapper mesh with base mesh
elems = hm.Collection(model, ent.Element)
model.adaptive_wrapper_init(collection=elems, clean_intersection=1, wrap_type=0)
# Build skeletal octree structure
model.adaptive_wrapper_build()
#Preview all cavities
model.adaptive_wrapper_preview()
#Clear the preview
model.adaptive_wrapper_preview_clear()
# Generate mesh
model.adaptive_wrapper_mesh(mesh_type=0, DoRemesh=1, RemeshGrowthRate=1.2)
# End of wrapper mesh
model.adaptive_wrapper_end()
