Model.morphconstraintupdatesmooth#
- Model.morphconstraintupdatesmooth(nlist, type, closed, mcon, color)#
Updates a smooth type morphconstraint for the selected nodes. During morphing, the perturbations of the nodes or dependent handles will be modified using a spline based approximation so that edge domains running along the selected entities will have smooth contours.
- Parameters:
nlist (EntityList) – The list containing the node entities.
type (int) –
0 - Apply to nodes. All handles on the node list serve as anchors for the spline curve and nodes are adjusted to the curve based on influences
1 - Apply to dependent handles. Only the independent handles on the node list serve as anchors and the dependent handles are adjusted to the curve based on influences
closed (int) –
0 - Open ended
1 - Loop. The first node on the list will be added to the end to form a loop
mcon (Entity) – The morph constraint entity to update.
color (int) – The color of the constraint. Valid values are 1 through 64.
Example#
Update a smooth morphconstraint for nodes with IDs 1-5 with a closed loop#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdatesmooth( nlist=[ ent.Node(model, 1), ent.Node(model, 2), ent.Node(model, 3), ent.Node(model, 4), ent.Node(model, 5), ], type=0, closed=1, mcon=ent.Morphconstraint(model, 12), color=32, )
