Model.elementtestvolumeareaskew#
Model.elementtestvolumeareaskew(collection, skew, output_collection, dimension, contour, title)#
Tests 2D and 3D elements using the volumetric and areal element quality check. The 3D volumetric skew corresponds directly to the Abaqus and Fluent CFD tetra element quality checks.
Parameters:
  • collection (Collection) – The collection containing the element entities to be checked.
  • skew (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
  • output_collection (Collection) – The collection containing the failed element entities.
  • dimension (int) –
    A code to measure the dimension of:
    2 - Measure 2D elements.
    4 - Measure 3D elements.
  • contour (int) –
    A flag that determines how the results are presented. Valid values are:
    0 - Display the results of the test normally.
    1 - Display the elements color coded by their ratings.
    2 - Build a histogram showing the distribution of ratings.
  • title (hwString) – The title to label the curve in the histogram. Only required, if contour is 2.
Examples#
Testing all displayed tetra elements for a volumetric skew of 0.6#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = model.CreateCollectionByDisplayed(ent.Element)
elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([])))
model.elementtestvolumeareaskew(
    collection=elems1,
    skew=0.6,
    output_collection=elems2,
    dimension=4,
    contour=0,
    title=""
Testing all displayed tria elements for an areal skew of 0.5#
import hm
model = hm.Model()
    collection=elems1,
    skew=0.5,
    dimension=2,
    contour=0,
    title=""
