Model.showentitybymark#
- Model.showentitybymark(collection_set, showcomps=False, elements_off=False, geometry_off=False)#
Turns on the display of a collection set of entities.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities. All entities with a display state on the specified collection set, regardless of entity type, are considered.
showcomps (bool) – This indicates that components in which elements/geometry are referred will also be shown when you show elements/geometry. If not provided, only specified elements/geometry are shown.
elements_off (bool) – This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
geometry_off (bool) – This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
Examples#
Show geometry and elements for components with IDs 1 - 3#import hm import hm.entities as ent model = hm.Model() comps_collection = hm.Collection(model, ent.Component, [1, 2, 3]) collection_set = hm.CollectionSet(model) collection_set.set(comps_collection) model.showentitybymark(collection_set=collection_set)
Show all components and load collectors, consider only elements#import hm import hm.entities as ent model = hm.Model() comps_collection = hm.Collection(model, ent.Component) loadcols_collection = hm.Collection(model, ent.Loadcol) collection_set = hm.CollectionSet(model) collection_set.set(comps_collection) collection_set.set(loadcols_collection) model.showentitybymark(collection_set=collection_set, geometry_off=True)
