Model.morphdisplayconstraintvector#
Model.morphdisplayconstraintvector(xp, yp, zp, xv, yv, zv, vv, op)#
Draws vector to the screen.
Parameters:
  • xp (double) – x value of vector base
  • yp (double) – y value of vector base
  • zp (double) – z value of vector base
  • xv (double) – x value of vector distance
  • yv (double) – y value of vector distance
  • zv (double) – z value of vector distance
  • vv (double) – Length of vector
  • op (int) –
    0 - Erase drawn vectors
    1 - Draw vector
Example#
A vector is drawn to the screen for the given values. If opt=0, all vectors are erased#
import hm
import hm.entities as ent
model = hm.Model()
model.morphdisplayconstraintvector(
    xp=1.0, yp=2.0, zp=3.0, xv=4.0, yv=5.0, zv=6.0, vv=10.0, op=1
Note
For HyperMesh versions 8.0 and higher this function is no longer used because constraints now always display.
