Model.hm_getmatrixdifference#
- Model.hm_getmatrixdifference(matrix_1, matrix_2)#
Given 4x4 transformation matrices, representing the orientation and positions of two geometric shapes A and B, return the transformation matrix that brings the A to B. This can be used in conjunction with
Model.hm_getorientation()that returns the transformation matrices for various entity types.- Parameters:
matrix_1 (hwDoubleList) – The first matrix, passed in as a list of 16 values.
matrix_2 (hwDoubleList) – The second matrix, passed in as a list of 16 values.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:transformationMatrix (numpy.ndarray) - The list of 16 values representing the 4x4 matrix M1-1M2
Examples#
Find the difference between the orientation of two selections of surfaces#import hm import hm.entities as ent def matToList(matrix: numpy.ndarray): """ Simple function that converts a numpy array of numpy arrays to list """ converted_list = list() for row in matrix: for col in row: converted_list.append(col) return converted_list model = hm.Model() # Orientation matrix for surfaces with IDs 22-44 on current model surface_collection_1 = hm.Collection(model, ent.Surface, list(range(22, 45))) _, resultlist = model.hm_getorientation(entityCollection=surface_collection_1) result = resultlist[0] # Length of resultlist = 1 in this case m1 = matToList(result.orientation) # Orintation matrix converted to list # Orientation matrix for surfaces with IDs 56-61 on current model surface_collection_2 = hm.Collection(model, ent.Surface, list(range(56, 61))) _, resultlist = model.hm_getorientation(entityCollection=surface_collection_2) result = resultlist[0] # Length of resultlist = 1 in this case m2 = matToList(result.orientation) # Orintation matrix converted to list _, result = model.hm_getmatrixdifference(matrix_1=m1, matrix_2=m2) print("Transformation Matrix:", result.transformationMatrix.reshape(4, 4))
Find the difference between the orientation of two components#import hm import hm.entities as ent def matToList(matrix: numpy.ndarray): """ Simple function that converts a numpy array of numpy arrays to list """ converted_list = list() for row in matrix: for col in row: converted_list.append(col) return converted_list model = hm.Model() # Orientation matrix for components with IDs 44, 45 on current model comps_collection_1 = hm.Collection(model, ent.Component, [44, 45]) _, resultlist = model.hm_getorientation( entityCollection=comps_collection_1, comparetype=1 ) result = resultlist[0] # Length of resultlist = 2 in this case m1 = matToList(result.orientation) # Orintation matrix converted to list result = resultlist[1] m2 = matToList(result.orientation) # Orintation matrix converted to list _, result = model.hm_getmatrixdifference(matrix_1=m1, matrix_2=m2) print("Transformation Matrix:", result.transformationMatrix.reshape(4, 4))
