Model.morphupdateparameter#
- Model.morphupdateparameter(parameter, value)#
Updates integer/real morphing parameters.
- Parameters:
parameter (hwString) –
The parameter of interest. Valid parameters are:
handlesize: The display size, in model units, of morphing handles.
symsize: The display size, in model units, of morphing symmetries.
morphconstraintsize: The display size, in model units or screen units, of morphing constraints.
Real > 0.0 - Value is size in model units.
Real < 0.0 - Absolute value is size in screen units.
domainicons: Show icons at the centroids of domains.
0 - Hide icons.
1 - Show icons.
mvdraw: number of points along morph volume edges during drawing.
mvgraph: style of graphics for morph volumes.
0 - Wireframe
1 - Light tint
2 - Opaque
3 - Medium tint
4 - Heavy tint
edgedomaincolor: Color for edge domains. Range is 1 through 64 inclusive.
facedomaincolor: Color for 2d domains. Range is 1 through 64 inclusive.
soliddomaincolor: Color for 3d domains. Range is 1 through 64 inclusive.
domaincolor: Color for 1d, global, and general domains. Range is 1 through 64 inclusive.
facecolor: Color for shell elements created on 3d domains. Range is 1 through 64 inclusive.
mvcolor: Color for morph volumes. Range is 1 through 64 inclusive.
symcolor: Color for symmetries. Range is 1 through 64 inclusive.
symlinks: Apply handle morphing to other handles linked by symmetry.
0 - All off.
1 - On (only active symmetries will be applied).
constraints: Apply constraints after morphing.
0 - All off.
1 - On (only active morphconstraints will be applied).
midnodes: Method for adjusting element midnodes during morphing.
0 - No correction.
1 - Force midpoint.
2 - Hold current.
3 - Curve edge domains.
4 - Curve 2D domains.
minstepdist: Minimum step size (in model units) for interactive morphing.
minstepangle: Minimum step size (in degrees) for interactive morphing.
handletolerance: No larger than 1/10th of handle size - used to calculate a number of small tolerance measures in.
biasstyle: Type of biasing used for handles.
0 - Exponential
1 - Sinusoidal
influencethreshold: Minimum influence of a handle over a node. Real number greater than zero and less than 1.0
qaparam: Element quality check to be displayed after each morph - where noted (+/-) use negative values for minimum check, positive values for maximum check.
0 - Off
1 - 1D length (+/-)
2 - 2D warpage
3 - 2D skew
4 - 2D aspect ratio
5 - 2D length (+/-)
6 - 2D jacobian
7 - 2D chordal deviation
8 - 2D quad angle (+/-)
9 - 2D tria angle (+/-)
10 - 3D warpage
11 - 3D aspect
12 - 3D tetra altitude aspect
13 - 3D skew
14 - 3D volumetric skew
15- 3D length (+/-)
16 - 3D jacobian
17 - 3D tetra collapse
18 - 3D quad angle (+/-)
19 - 3D tria angle (+/-)
23 - All elements time step
24 - 2D Equia skew
25 - 2D Squish
26 - 2D Taper
27 - 3D Squish
28 - 3D Equia Skew
29 - 3D Orthogonality
30 - 3D Size Ratio
99 - Quality Index
qavalue: The upper or lower failure limit for element quality.
qaplot: Type of plotting of failed elements during element quality check.
0 - Highlight failed elements.
1 - Used color assigned plot.
qanegjac: Scan morphed elements for negative Jacobians after each morph.
0 - Off
1 - On
smoothmeth: Method used for automatic smoothing (use positive values to smooth after interactive morphing, negative value to smooth during interactive morphing).
0 - None
1 - Autoselect
2 - Size corrected
3 - Shape corrected
4 - Angle corrected
5 - QI optimized
6 - Kriging (or autodecide for elements outside of local domains)
7 - Kriging (or size corrected for elements outside of local domains)
8 - Kriging (or shape corrected for elements outside of local domains)
9 - Kriging (or angle corrected for elements outside of local domains)
10 - Kriging (or QI optimized for elements outside of local domains)
11 - Kriging (ignore elements outside of local domains)
12 - Unsquish (fast)
13 - Unsquish (even)
14 - Unsquish (best)
smoothiter: Number of iterations for smoothmeth (options 1 - 4 and 6 - 9 only).
remesh: When remeshing after morphing occurs.
0 - Off
1 - Manual
2 - On release
rmlast: Remesh interval - use “
hm_getoption morph_remeshing_interval()” to retrieve the current value for this option, if the value is:> -1: Remesh all morphed elements since the last remesh.
< -8: Remesh only morphed elements for the most recent morph to change from one mode to the other set to (current_value * -1.0) - 10.0.
rmstyle: Rremesh or rebuild the morphed mesh.
0 - Remesh
1 - Rebuild
remeshtype: Elements used when auto-remeshing.
0 - trias
1 - quads
2 - mixed
3 - right trias
rmcalc: How the remeshing target element size is set.
0 - Average elements to be remeshed.
1 - Use element size in the criteria file.
2 - Set value manually.
remeshtarg: Target size of remeshed elements during auto-remeshing.
rmedges: Remesh edge domains during auto-remeshing.
0 - Do not remesh edge domains.
1 - Remesh edge domains.
remeshfail: Percentage of failed elements needed to trigger auto-remeshing.
rmzone: How much of the morphed mesh to remesh.
0 - All morphed elements.
1 - Only failed elements.
2 - Failed elements + 1 row.
3 - Failed elements + 2 rows.
4 - Failed elements + 3 rows.
remeshsize: Bias toward similar element size during remeshing.
0 - Off
1 - On
remeshskew: use skew control when auto-remeshing.
0 - Off
1 - On
remeshpres: Preserve shapes when auto-remeshing.
0 - Off
1 - On
rmthreed: remesh 3D elements with pyras and tretras during auto-remeshing.
0 - Do not remesh 3D and 2D face domains.
1 - Remesh 3D and 2D face domains.
mvon: Morphing of entities inside of morph volumes.
-1 - Inactive and skin only
0 - Inactive
1 - Active
2 - Active and skin only
mvmode: Method for calculating morph volume edge curvature
0 - Lagrange
1 - spline
mvreparam: Either maintain the initial continuity between linked edges or reset it.
0 - Maintain during morphing and during adjustment.
1 - Maintain during morphing but reset after adjustment.
2 - Reset during morphing but maintain after adjustment.
3 - Reset during morphing and after adjustment.
mvtol: 0.0 - 1.0, mapping tolerance - accuracy increases as tolerance decreases
mvconnreg: Which connectors get registered to morphvolumes during creation and after adjustment.
0 - All
1 - Displayed connectors
2 - None
mvconnreal: Treatment of registered connectors during morphing.
0 - Maintain
1 - Unrealize
2 - Unrealize + rerealize
connectors: Style of morphing for connectors (add 10 to use the large domain solver to smooth over distortions in the mesh around clusters during morphing).
0 - Use domains/morph volumes.
1 - Solve all as clusters.
2 - Solve all as stretchable.
3 - Solve seam and area connectors as stretchable and others as clusters.
4 - As 3 above but treat equations as clusters.
5 - As 3 above but do not apply special treatment to equations.
onedrot: rotation of clusters (1d domains and morphconstraints), connectors, and equations
0 - No rotation
1 - Tilting only (out-of-plane)
2 - Spinning only (in-plane)
3 - Full rotation
globalsystemid: ID of system used for morphing (use 0 for the global system).
globalmethod: Method for passing down perturbations of global handles to the mesh.
1 - Direct (to nodes)
2 - Hierarchical (to local handles)
3 - Mixed method (to local handles or nodes directly if outside local domains)
globalsolve: Method for solving global domains.
1 - Geometric
2 - Spatial
3 - Kriging
onedmethod: Method used to determine the relationship between 1D domains and their surrounding domains.
1 - Independent
2 - Secondary
3 - Main
4 - Cluster
savemorphlist: Save morph list with HM binary format file.
0 - Do not save morph list with file.
1 - Save morph list with file.
morphlibarch: If the morphing library is used and what the preferred computation method is for it.
0 - Do not use morphing library (large domain solver).
1 - Use morphing library but only with single CPU.
2 - Use morphing library with multiple CPUs.
3 - Use morphing library and use GPU if available.
bigdomainsolve: When the large domain solver runs.
0 - Manual
1 - On release
2 - Real time
morphlibunfold: Whether the large domain solver runs when the mesh gets folded.
0 - Never unfold.
1 - Ask to unfold.
2 - Always unfold.
bigdomainlimit: Smallest number of elements in domain for it to be considered a “large domain”.
fesolver: Type of solver to use for small domains.
0 - Influence coefficients
1 - Lagrangeinear static ()
2 - Non-linear explicit ()
3 - Kriging
fesolve: When the small domain solver runs.
0 - Manual
1 - On release
2 - Real time (interactive)
fesolverlimit: Number of elements at or below which a domain is considered a small domain.
feuser: Properties used when running linear static or nonlinear explicit small domain solvers.
0 - Automatically generate properties and materials.
1 - Use properties and materials in the model.
qaautofix: Invoke the large domain solver to unfold small domains which become folded during morphing.
0 - Off
1 - Autofix on release
2 - Autofix in real time (interactive)
kriging: When the kriging solver runs.
0 - Off
1 - Manual
3 - Automatic
krigtype: Kriging will be applied to the following entities.
0 - None
1 - Global domains
2 - Local domains
3 - Local and global domains
4 - Morph volumes
5 - Morph volumes and global domains
6 - Morph volumes and local domains
7 - Morph volumes, local, and global domains
krigdrift: Drift value for kriging.
0 - None
1 - Constant
2 - Linear
3 - Quadratic
4 - Cubic
5 - Trigonometric
krigcovar: Covariance value for kriging.
0 - h
1 - h^2 * log(h)
2 - h^3
3 - exp(-1/x)
krignugget: Use nugget value.
0 - Off
1 - On
krignugval: Value of nugget used for kriging.
ires: When to display fea results after morphing.
0 - Off
1 - Manual
2 - On release
3 - Real time
irescon: Plotting style for fea results.
0 - Contour plot.
1 - Assign plot.
iresmin: Set the scale minimum value for fea results plotting.
0 - Find minimum value.
1 - Use value given in iresminval.
iresminval: Value of scale minimum used when plotting fea results.
iresmax: Set the scale maximum value for fea results plotting.
0 - Find maximum value.
1 - Use value given in iresmaxval.
iresmaxval: Value of scale maximum used when plotting fea results.
irescomp: Results component for fea results plotting.
0 - Magnitude
1 - x component
2 - y component
3 - z component
iresmesh: Color of mesh during fea results plotting. Range is 1 through 64 inclusive.
iresmmres: Minimum/maximum title plotting during fea results plotting.
0 - Do not plot minimum and maximum titles.
1 - Plot minimum and maximum titles.
iresplinfo: Info title plotting during fea results plotting.
0 - Do not plot info titles.
1 - Plot info titles.
iressolver: Solver used for fea results plotting.
1 - Linear static
2 - Nonlinear explicit
3 - Stamping 1-step
4 - Stamping incremental
iresstmpx: x component of the stamping direction for the 1-step solver.
iresstmpy: y component of the stamping direction for the 1-step solver.
iresstmpz: z component of the stamping direction for the 1-step solver.
partitionmethod: Algorithm used for partitioning 2D domains which are at least 33%.
0 - Element based
1 - Node based
partitionmethodtria: Algorithm used for partitioning 2D domains which are at least 67% trias.
0 - Element based
1 - Node based
domainangle: Break angle, in degrees, for determining partition lines partitionorder.
1 - Divide when angle exceeds the domainangle.
2 - Divide when angle exceeds the domainangle and when the angle between elements changes more than the curvetolerance.
curvetolerance: The tolerance value (in degrees) for curvature changes which determine partition lines.
partitionusegeometry: Partition along surface edges of associated geometry.
0 - Off
1 - On
partitionaddgeometry: Merge partitioned domains and those created from geometry (where applicable).
0 - Off
1 - On
internalpart: Partition faces inside solid meshes.
0 - Off
1 - On
value (double) – The new value of the parameter.
Example#
Update the current bias style for handles to sinusoidal#import hm import hm.entities as ent model = hm.Model() model.morphupdateparameter(parameter="biasstyle", value=1)
