Model.unrealizeengineeringentity#
Model.unrealizeengineeringentity(entity, unrealize_mode)#
Unrealizes an engineering entity.
Parameters:
  • entity (Entity) – The object describing the entity to be unrealized.
  • unrealize_mode (int) –
    0 - Delete entities from realization. Only current solver/profile is affected.
    1 - Maintain entities from realization. Only current solver/profile is affected.
    10 - Delete entities from realization. All entities including other solvers/profiles are affected.
    11 - Maintain entities from realization. All entities including other solvers/profiles are affected.
Example#
Unrealize mass with ID 10#
import hm
import hm.entities as ent
model = hm.Model()
model.unrealizeengineeringentity(entity=ent.Solvermass(model, 10), unrealize_mode=0)
