Model.hm_attributeindextype#
- Model.hm_attributeindextype(entity_type, entity_id, attribute_index)#
Returns the attribute type number of an indexed attribute on an entity.
- Parameters:
entity_type (EntityFullType) – The type of entity to query.
entity_id (unsigned int) – The ID of the entity.
attribute_index (int) – The index of the attribute owned by the queried entity (starting at 1).
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:type (int) - The values returned have the following meanings:
1 - integer
2 - double
3 - string
4 - 1D integer array
5 - 1D double array
6 - entity
7 - (not supported)
8 - (not supported)
9 - 2D integer array
10 - 2D double array
11 - string array
12 - 1D entity array
13 - 2D entity array
Example#
Get the attribute type number of the attribute with index 4 on property with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributeindextype( entity_type=ent.Property, entity_id=1, attribute_index=4 ) print("Type", result.type)
