Model.geomnormalignmentmode#
Model.geomnormalignmentmode(mode)#
Sets the surface normal alignment mode. This applies both to the panel behavior, and the Model.surfacereversenormals2() API.
Parameters:
mode (int) –
0 - Individual surfaces cannot be reversed. Normal consistency is maintained via the API and panel by extending the selection to the minimum set of surfaces.
1 - Individual surfaces can be reversed via the API. Normal consistency is maintained via the panel by extending the selection to all connected surfaces. This is the pre-11.0 behavior.
