Model.beams_to_surfaces#
- Model.beams_to_surfaces(collection=Collection(), convert1DToSolid=0, domesh=True, meshextension=False, meshsize=0.0, meshtype=2, referencepoint='shearcenter', shellsectiondestination='sortbycurrent', smoothcurves=False, stitchtol=0.0, surfacecreationtype='surfacebyguidelines', tobeamcomponent=0.0, x_breakangle=0.0, y_breakangle=0.0)#
Creates surfaces/meshes from 1D beams. The beams must have valid section data assigned.
- Parameters:
collection (Collection) – The collection containing the input entities.
convert1DToSolid (int) –
Specifies whether to create 2D surfaces or 3D solids from the beam.
0 - creates 2D surfaces (default)
1 - creates 3D solids (valid only for standard sections)
domesh (bool) –
Specifies whether the generated surfaces should be meshed. Valid only when
convert1DToSolid=0.0 - Do not mesh
1 - Mesh (default)
meshextension (bool) –
Specifies whether the generated mesh should be extended to the connected surfaces:
0 - Do not extend (default)
1 - Extend
meshsize (double) – The size of the mesh when
domesh=True. The default is the global element size.meshtype (int) –
Specifies the mesh element type when
domesh=True:0 - Tria
1 - Quad only
2 - Mixed (default)
referencepoint (hwString) –
Describes the reference point of the beam to be used for surface creation:
beamnode - Surfaces are congruent with the beam nodes. Not valid when
convert1DToSolid=1.centroid - Reference point is used as the centroid of the beam section.
shearcenter - Reference point is used as the shear center of the beam section.
shellsectiondestination (hwString) –
The surface/mesh component organization in shell section only.
sortbycurrent - Current component (default)
sortbysource - Source beam 1D component
sortbypart - Component with part-name as name
sortbythickness - Component with part-name and thickness value as name
smoothcurves (bool) –
Specifies to have smooth surfaces or straight surfaces at the beam for shell sections only.
0 - Straight segments
1 - Smooth segments (default)
stitchtol (double) – The stitch tolerance when dosnap=1. The default is the global geometry cleanup tolerance.
surfacecreationtype (hwString) –
The surface generation mode for shell sections only.
surfacebyguidelines - Create surface using the guidelines formed by connecting points of each section (default)
surfacebysections - Create surfaces at each section
tobeamcomponent (double) –
Specifies the surface/mesh component organization:
0 - Current component (default)
1 - Source 1D component
x_breakangle (double) – The angle value in degrees to break the source 1D chain.
y_breakangle (double) – The angle value in degrees to break the beam offset.
Example#
Create surfaces and mixed mesh of size 100.0, snapping the surfaces, extending the mesh, and making the surfaces and mesh congrument with the base mesh#import hm import hm.entities as ent model = hm.Model() model.beams_to_surfaces( collection=hm.Collection(model, ent.Element), convert1DToSolid=0, domesh=True, meshextension=True, meshsize=100.0, meshtype=2, stitchtol=0.0, tobeamcomponent=0.0, )
