Model.PenetrationCheckSummary#
- Model.PenetrationCheckSummary(filename, sort_intersections, sort_penetrations)#
This function is used to generate a summary log file for last run penetration check. This file contains a flat list of intersected and penetrated components, followed by more detailed lists of each component-component pair data. If the last check’s input was specified by groups, then the above data is organized by groups, as well.
- Parameters:
filename (hwString) – The name of the file, including its full path, to which the summary is written. The file is appended to if it already exists.
sort_intersections (int) –
A flag that indicates how to sort intersection data. Valid values are:
-3 - Descending number of interfered components
-2 - Descending element count
-1 - Descending component ID
0 - No sorting
1 - Ascending component ID
2 - Ascending element count
3 - Ascending number of interfered components
sort_penetrations (int) –
A flag that indicates how to sort penetration data. Valid values are:
-4 - Descending maximum penetration depth
0 - No sorting
4 - Ascending maximum penetration depth
Example#
Output results of the last penetration check (run using the functioncheckpenetration()) to the file “C:/results/check.txt”, with intersections sorted by ascending component ID and penetrations by descending maximum penetration depth#import hm import hm.entities as ent model = hm.Model() model.PenetrationCheckSummary( filename="C:/results/check.txt", sort_intersections=1, sort_penetrations=-4 )
