Model.hm_compareentitiesposition#
- Model.hm_compareentitiesposition(source_entities, target_entities, tolerance, n1_source, n2_source, n3_source, n1_target, n2_target, n3_target, result_type=1, review_results=True)#
Generates comparison results for entities positioned at a specific location. This must be preceded by a call to
Model.hm_compareinit().These results can then be queried using hm_compareget APIs, or written to a file using hm_comparewrite APIs.
- Parameters:
source_entities (Collection) – The collection containing the source entities. Valid entities are surfaces or elements.
target_entities (Collection) – The collection containing the target entities. Valid entities are surfaces or elements.
tolerance (double) – The tolerance value to use for the comparison.
n1_source (Entity) – The object describing the node entity of the source entity base (N1).
n2_source (Entity) – The object describing the node entity of the source entity x-direction (N2).
n3_source (Entity) – The object describing the node entity of the source entity xy-plane (N3).
n1_target (Entity) – The object describing the node entity of the target entity base (N1).
n2_target (Entity) – The object describing the node entity of the target entity x-direction (N2).
n3_target (Entity) – The object describing the node entity of the target entity xy-plane (N3).
result_type (int) –
SURFS to SURFS
SURFS to ELEMS
ELEMS to SURFS
ELEMS to ELEMS
0 - Basic
Matched (paired)
Unmatched
Matched (paired)
Unmatched
Matched
Unmatched
1 - Full (default)
Matched (paired)
Overlapped
Intersected
Unmatched
Matched (paired)
Overlapped
Intersected
Unmatched
Matched
Overlapped
Intersected
Unmatched
2 - Detailed
Matched (paired)
Overlapped (paired)
Intersected (paired)
Unmatched
Matched (paired)
Overlapped (paired)
Unmatched
Matched
Overlapped (paired)
Unmatched
review_results (bool) –
False - Do not automatically show the graphical comparison results after execution.
True - Automatically show the graphical comparison results after execution (default). This is cleared upon a call to hm_compareend.
- Returns:
hwReturnStatus- Status object
Example#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the comparison of surfs with IDs 1 - 20 and 101 - 120 with source N1 / N2 / N3 nodes with IDs 100/101/102 and target N1 / N2 / N3 nodes with IDs 200/201/202#import hm import hm.entities as ent model = hm.Model() surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesposition( source_entities=surfs1, target_entities=surfs2, tolerance=0.1, n1_source=ent.Node(model, 100), n2_source=ent.Node(model, 101), n3_source=ent.Node(model, 102), n1_target=ent.Node(model, 200), n2_target=ent.Node(model, 201), n3_target=ent.Node(model, 202), result_type=2, review_results=False, ) model.hm_comparewriteresults( filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0 ) model.hm_compareend()
