Model.attributeupdatestring#
- Model.attributeupdatestring(entity, identifier, solver, status, behavior, value)#
Updates an attribute of type string (
hwString()).- Parameters:
entity (Entity) – The object describing the entity that owns the attribute.
identifier (int) – The identifier of the attribute.
solver (int) – The solver number of the attribute.
status (int) – The status of the attribute.
behavior (int) – The behavior of the attribute.
value (hwString) – The value of the attribute.
Example#
Update the load collector with ID 74 in * IMPERF_TYPE * dataname (identifier=11340) in Optistruct profile by set attribute to * GRID *#import hm import hm.entities as ent model = hm.Model() # Finding the IMPERF_TYPE identifier using the hm_attributeidentifier function _, r = model.hm_attributeidentifier( entity_type=ent.Loadcol, entity_id=74, attribute_name_or_id="IMPERF_TYPE" ) # Setting the dataname model.attributeupdatestring( entity=ent.Loadcol(model, 74), identifier=r.id, solver=1, status=2, behavior=0, value="GRID", )
