Model.unmasksegments#
- Model.unmasksegments(set_ids, elem_ids, face_indices, consider_elems=False)#
Unmasks segments. A segment is defined using its corresponding set ID, element ID, and face index.
- Parameters:
set_ids (hwIntList) – The ordered list of set IDs from which the segments need to be unmasked.
elem_ids (hwIntList) – The ordered list of element IDs corresponding to the segments.
face_indices (hwIntList) – The ordered list of face indices corresponding to the segments.
consider_elems (bool) – Flag to consider underlying structural elements during unmasking of the segments.
Example#
Unmask segments with face indices 4 and 3 on element with ID 78 from set with ID 5#import hm import hm.entities as ent model = hm.Model() # Creating a list of integer values that contains the set IDs from which the segments need to be unmasked set_ids_list = [5, 5] # Creating a list of integer values that contains the element IDs corresponding to the segments elem_ids_list = [78, 78] # Creating a list of integer values that contains the face indices corresponding to the segments face_ids_list = [4, 3] model.unmasksegments( set_ids=set_ids_list, elem_ids=elem_ids_list, face_indices=face_ids_list )
