Model.ossmooth_savesurf#
- Model.ossmooth_savesurf(mode, filepath, units, output)#
Exports the final design geometry from OptiStruct topology, topography and shape optimization results.
- Parameters:
mode (int) –
0 - Create .oss file only to be used in standalone version (do not execute OSSmooth)
1 - Do not load geometry into HyperMesh.
2 - Load geometry into HyperMesh.
filepath (hwString) – The full name and path of the OptiStruct .fem results file generated from the optimization.
units (int) –
Units used for IGES and STEP output. Valid values are:
1 - inch
2 - mm
4 - foot
6 - meter
10 - cm
output (int) –
1 - Nastran
2 - IGES
3 - STL
4 - H3D
5 - STEP
6 - PARASOLID
7 - IGES (advanced)
Example#
Execute OSSmooth to save surfaces to STEP file “ C:/test / os1.step “ , use mm as units#import hm import hm.entities as ent model = hm.Model() model.ossmooth_savesurf(mode=2, filepath="C:/test/os1.fem", units=2, output=5)
