Model.createsketchfrombeamsection#
Model.createsketchfrombeamsection(beamsections, assignsketch=True, computeproperties=False, offset=hwDoubleList())#
Creates a sketch from shell or solid beamsections.
Parameters:
  • beamsections (Collection) – The collection containing the input beamsections entities.
  • assignsketch (bool) –
    After sketch creation, assign the sketch to the beamsection.
    False - Do not assign
    True - Assign (default)
  • computeproperties (bool) –
    If assignsketch=1, use the sketch to recompute new beamsection properties.
    False - Do not compute (default)
    True - Compute
  • offset (hwDoubleList) – Offset in local beamsection system to add to the sketch.
Example#
Create a sketch from a beamsection#
import hm
import hm.entities as ent
model = hm.Model()
beamsects = hm.Collection(model, ent.Beamsection, list(range(1, 11)))
model.createsketchfrombeamsection(beamsections=beamsects)
Create an offset sketch and recompute properties#
import hm
model = hm.Model()
beamsects = hm.Collection(model, ent.Beamsection, populate=True)
model.createsketchfrombeamsection(beamsections=beamsects, computeproperties=Tue, offset=[1.0, 2.0])
