Model.morphmaptotacitvecoffset#
- Model.morphmaptotacitvecoffset(collection_nodes, collection_handles, collection_elems, use_symmetry, use_constraints, project, vector, mode, offset)#
Maps nodes to, or offset from, a collection of elements using the temporary shape created by
Model.morphmaptshp()andModel.morphmaptshpedge()as a guide. Selected handles can optionally follow behind the morphing operation.Nodes can be projected on to the target elements along a vector, normal to the target elements, or projected normal to the elements touching the nodes.
- Parameters:
collection_nodes (Collection) – The collection containing the entities.
collection_handles (Collection) – The collection containing the entities.
collection_elems (Collection) – The collection containing the entities.
use_symmetry (int) – 0 - Do not use symmetry (only option)
use_constraints (int) –
0 - Do not use constraints
1 - Use constraints
project (int) –
0 or 10 - Project along vector defined by
vector1 or 11 - Project normal to the elements on the collection
2 or 12 - Project normal to shell elements touching nodes
If
offsetis non-zero, the offset will be measured from the closest point on the elements for values of 0 and 1. The offset will be measured along the projection vector or normal for values of 10, 11 and 12.vector (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
mode (int) –
0 - If
Model.morphmaprecalc()has been used to calculate new influences1 - To recalculate new influences inside this function
offset (double) –
The distance to offset nodes from the target.
The offset will be measured from the closest point on the elements for values of
projectof 0, 1, and 2.The offset will be measured along the projection vector normal for values of
projectof 10, 11, and 12.
Example#
Map all nodes to elements with IDs 1-100 with an offset of 1.2 when not usingModel.morphmaprecalc()#import hm import hm.entities as ent model = hm.Model() model.morphmaptotacitvecoffset( collection_nodes=hm.Collection(model, ent.Node), collection_handles=hm.CollectionByInteractiveSelection(model, ent.Handle), collection_elems=hm.Collection(model, list(range(1, 101))), use_symmetry=0, use_constraints=1, project=2, vector=[1.0, 0.0, 0.0], mode=1, offset=1.2, )
