Model.fastenercreation#
Model.fastenercreation(coeffa=0.0, coeffb1=0.0, coeffb2=0.0, component_collection=Collection(), geom_collection=Collection(), conntype='Bolts', createupdateoption=0, diameter=0.0, diameteropt='Value', elemtype='FASTENER', fileloc='', filelocopt=False, k4=0.0, k5=0.0, k6=0.0, material=Entity(), method='', numlayer=-1, numlayeropt='Calculated', orientopt='Auto', projectiondirection=hwTriple(0.0, 0.0, 0.0), projectionmethod='normal to links', projectionspecificlink=Entity(), system=Entity(), tolerance=10.0, toleranceopt='', youngmodopt='')#
Creates fastener connectors, elements, properties, and materials using the Huth formula. Currently only supported for Abaqus profile.
Valid column labels in the CSV file are:
  • x,y,z for location
  • x1,y1,z1,x2,y2,z2 for start and end point of line
  • lineid for ID of line
  • nodeid for ID of node
  • pointid for ID of point
  • material for ID of material
  • diameter for fastener diameter
  • tolerance or length for tolerance of line
  • cid for system ID if the locations are in a specific system
The default Huth constants are:
  • Coefficient a: 2/3 for metallic and bolted graphite/epoxy, 2/5 for riveted metallic
  • Coefficient b: 3 for bolted metallic, 2.2 for riveted metallic, 4.2 for bolted graphite/epoxy
  • Coefficient b1=b/n b2=b/n^2 where n is the number of shear
Parameters:
  • coeffa (double) – The a value when method=”User defined(Huth)”.
  • coeffb1 (double) – The b1 value when method=”User defined(Huth)”.
  • coeffb2 (double) – The b2 value when method=”User defined(Huth)”.
  • component_collection (Collection) – The collection containing the entities for finding attached shells or projections.
  • geom_collection (Collection) – The collection containing the entities for creating (lines, points, nodes) and updating (connectors) operations.
  • conntype (hwString) – The connection type, Bolts or Rivets.
  • createupdateoption (int) –
    0 - Connector creation
    1 - Connector post-processing for creating materials, properties, etc…
  • diameter (double) – The diameter value when diameteropt=Value.
  • diameteropt (hwString) –
    Calculated - Consider from file if it has diameter information, else from perpendicular lines on component_collection
    Value - Specified via diameter
  • elemtype (hwString) – The solver element type. Must be set to Fastener for creating CONN3D in .
  • fileloc (hwString) – The full file path which contains values like diameter, line ID, node ID, point ID, material ID, point location, etc… when filelocopt=1.
  • filelocopt (bool) – If set to True, fileloc is used.
  • k4 (double) – The stiffness value k4.
  • k5 (double) – The stiffness value k5.
  • k6 (double) – The stiffness value k6.
  • material (Entity) – The object describing the material entity when youngmodopt=material.
  • method (hwString) –
    “Huth Formula”
    ”User defined(Huth)” - Must specify coeffa, coeffb1, and coeffb2.
  • numlayer (int) – The number of layers when numlayeropt=Value.
  • numlayeropt (hwString) –
    Calculated - Automatic calculation (default)
    Value - Specified via numlayer
  • orientopt (hwString) –
    The orientation option:
    Auto - Automatic (default)
    UserDefined - Specified via system
  • projectiondirection (hwTriple) – The direction values when projectionmethod="along discrete direction"
  • projectionmethod (hwString) –
    The method for calculating the projection. Valid values are:
    ”along discrete direction”
    ”normal to closest link”
    ”normal to furthest link”
    ”normal to links” (default)
    ”normal to specific link”
  • projectionspecificlink (Entity) – The object describing the component entity when projectionmethod="normal to specific link".
  • system (Entity) – The object describing the system entity when orientopt=UserDefined.
  • tolerance (double) – The tolerance value when toleranceopt=Value.
  • toleranceopt (hwString) –
    The connector tolerance:
    Calculated - Automatic calculation from lines
    Value - Specified via tolerance
  • youngmodopt (hwString) –
    material - Value is taken from material.
    <value> - The specific value to use
Example#
Create fasteners on all lines (via comps), with diameter of 5, automatic number of layers, Young’s modulus taken from material 1, and the tolerance calculated using lines#
import hm
import hm.entities as ent
model = hm.Model()
comps = hm.Collection(model, ent.Component)
lines = hm.Collection(model, ent.Line)
model.fastenercreation(
      component_collection=comps,
      geom_collection=lines,
      conntype="Bolts",
      diameter=5.0,
      diameteropt="Value",
      elemtype="FASTENER",
      filelocopt=False,
      k4=100.0,
      k5=1.0E8,
      k6=1.0E8,
      material=ent.Material(model, 1),
      method="Hutch Formula",
      numlayer=-1,
      numlayeropt="Calculated",
      orientopt="Auto",
      toleranceopt="Calculated",
      youngmodopt="material"
