Model.blockwallremove# Model.blockwallremove(blockname, wallname)# Removes all cells from the given finite difference wall. Parameters: blockname (hwString) – The name of the block. wallname (hwString) – The name of the wall from which all cells are to be removed. Example# Remove a wall with name “wall1” from block with name “block1”# import hm model = hm.Model() model.blockwallremove(blockname="block1", wallname="wall1")
