Model.set_default_quality_criteria#
- Model.set_default_quality_criteria(elementsize)#
Sets the default criteria, adjusted to a specified element size, as the current quality criteria.
- Parameters:
elementsize (double) – The double value of the ideal element size for the criteria to be set.
Example#
Reset the current values in the quality index panel#import hm import hm.entities as ent model = hm.Model() model.set_default_quality_criteria(3.5)
