Model.xyplotcurvemodify#
Model.xyplotcurvemodify(curve_name, item_name, string, value, plot)#
Modifies a curve.
Parameters:
  • curve_name (hwString) – The name of the curve being modified.
  • item_name (hwString) – The name of the item of data being modified.
  • string (hwString) – The string value of the item.
  • value (double) – The value of the item.
  • plot (int) – A logical which determines if the current xy plot should be replotted when the change is made to the curve.
Example#
Change the title name to “Curve1”#
import hm
import hm.entities as ent
model = hm.Model()
model.xyplotcurvemodify(
    curve_name="mycurve", item_name="title", string="Curve1", value=0.0, plot=1
