Model.setelemparamcolor#
- Model.setelemparamcolor(param_id, color)#
Sets the color for all element quality parameters for elements violating the threshold. This function is related to the element quality view mode.
- Parameters:
param_id (int) –
Specifies the element quality check parameter ID to update. Valid values are:
0 - min size
1 - max size
2 - aspect ratio
3 - warpage
4 - max interior angle quad
5 - min interior angle quad
6 - max interior angle tria
7 - min interior angle tria
8 - skew
9 - Jacobian
10 - chordal deviation
11 - quality index
color (int) – The color to use. Valid values are 1-64.
Example#
Set “aspect ratio” color to brown#import hm import hm.entities as ent model = hm.Model() model.setelemparamcolor(param_id=2, color=28)
