Model.surfacecopyedges#
- Model.surfacecopyedges(surface, entitylist, all_edges)#
Create lines from the edges of a surface.
- Parameters:
surface (Entity) – A surface that contains edges (a full sphere or torus does not contain edges).
entitylist (EntityList) – The list of the nodes used to select the surface edges (if
all_edges=0).all_edges (int) –
0 - Only copy edges that have a node created on them (from list).
1 - Copy all edges of the surface to new lines.
Example#
Copy all edges of surface with ID 1 to new lines#import hm import hm.entities as ent model = hm.Model() model.surfacecopyedges(surface=ent.Surface(model, 1), entitylist=ent.Node.getentitylist(), all_edges=1)
