Model.mechadjustballjoint#
- Model.mechadjustballjoint(name, x, y, z, tolerance, lock, angle_step)#
Actuates a ball joint to reach a new value. The mechanism must have the enabled flag set to true for this to be possible.
- Parameters:
name (hwString) – The name of the joint to adjust.
x (double) – The desired x Euler angle value of the joint.
y (double) – The desired y Euler angle value of the joint.
z (double) – The desired z Euler angle value of the joint.
tolerance (double) – The tolerance allowed when adjusting.
lock (unsigned int) – If set to 1, all joints in the mechanism which are not part of the cycle of the given joint are locked.
angle_step (double) – The size of the iterative steps used to solve for the new value of the joint. Only used for rotation.
Example#
Move a joint named “TORSO_to_RIGHT_UPPER_LEG” tox=20.0,y=0.0,z=0.0with a tolerance of 0.001 , lock other joints and angle step equal to 0.0#import hm import hm.entities as ent model = hm.Model() model.mechadjustballjoint( name="TORSO_to_RIGHT_UPPER_LEG", x=20.0, y=0.0, z=0.0, tolerance=0.001, lock=1, angle_step=0.0, )
