Model.hm_collisiongetcomponententitypaircount#
- Model.hm_collisiongetcomponententitypaircount(collision_type, component_index, include_ignored=False)#
Returns the number of entity pairs for a component collision pair. This must be preceded by a call to relevant hm_collision functions to generate the collision data. In addition, the
pair_resultsargument atModel.hm_collisioncheck()must be set toTrue.For each collision type there is a list of pairs of colliding components. For each colliding component pair, there is a list of colliding entity pairs. Thus, their is a hierarchy of data with the tree looking like this:
collision type \(\rightarrow\) component pairs \(\rightarrow\) entity pairs
The data is therefore accessed as:
Get the number of colliding component pairs
Get the component IDs for each component pair
Get the number of intersected entities for each component pair
Get the entity types, IDs, and faces (for intersections) or the entity types, IDs, faces, depths and directions (for penetrations) for each intersected entity pair.
- Parameters:
collision_type (int) –
The type of collision to query:
0 - intersections
1 - penetrations
component_index (int) – The index of the component pair to query, starting from 0. The total number of component pairs for a specific
collision_typecan be found usingModel.hm_collisongetcomponentpaircount().include_ignored (bool) –
Specifies if results ignored when the
allowable_depthvalue which is specified viaModel.hm_collisioninit()should be reported or not:False - Do not include ignored results (default).
True - Include ignored results.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:numberOfEntityPairs (int)
Examples#
Find intersect surfaces from IDs 1 - 10 , and to get the detailed list of entities for each intersection#import hm import hm.entities as ent model = hm.Model() model.hm_collisioninit() checking_surfs = hm.Collection(model,ent.Surface,list(range(1,11))) model.hm_collisioninit() model.hm_collisionentitycreate(collection=checking_surfs,dimension=0,thickness_type=1, thickness=0,edge_penetration=0,midside_nodes=0,split_quads=0, used_topology=0,grouping_identifier=False,offset=0 ) pene_surfs = hm.Collection(model,ent.Surface,populate=False) model.hm_collisioncheck(penetrated_surfaces=pene_surfs,pair_results=True) _, result = model.hm_collisiongetcomponentpaircount(collisionType=0) component_pair_count = result.numberOfCollisionPairs if component_pair_count > 0: for i in range(0,component_pair_count): _, result = model.hm_collisiongetcomponententitypaircount(collision_type=0,component_index=i) entity_pair_count = result.numberOfEntityPairs if entity_pair_count !=0: for j in range(0,entity_pair_count): _, result = model.hm_collisiongetcomponententitypair(collision_type=0,component_index=i,entity_index=j) print("Collision entity1 [type, id, faceIndex]: ", [result.entityType1, result.entityID1, result.faceIndex1]) print("Collision entity2 [type, id, faceIndex]: ", [result.entityType2, result.entityID2, result.faceIndex2]) model.hm_collisionend()
Find intersect surfaces from IDs 1 - 10 , use the thickness assigned to the surface components , and to get the detailed list of entities for each intersection#import hm import hm.entities as ent model = hm.Model() model.hm_collisioninit() checking_surfs = hm.Collection(model,ent.Surface,list(range(1,11))) model.hm_collisioninit() model.hm_collisionentitycreate(collection=checking_surfs,dimension=0,thickness_type=1, thickness=0,edge_penetration=0,midside_nodes=0,split_quads=0, used_topology=0,grouping_identifier=False,offset=0 ) pene_surfs = hm.Collection(model,ent.Surface,populate=False) model.hm_collisioncheck(penetrated_surfaces=pene_surfs,pair_results=True) _, result = model.hm_collisiongetcomponentpaircount(collisionType=1) component_pair_count = result.numberOfCollisionPairs if component_pair_count > 0: for i in range(0,component_pair_count): _, result = model.hm_collisiongetcomponententitypaircount(collision_type=1,component_index=i) entity_pair_count = result.numberOfEntityPairs if entity_pair_count !=0: for j in range(0,entity_pair_count): _, result = model.hm_collisiongetcomponententitypair(collision_type=1,component_index=i,entity_index=j) print("Collision entity1 [type, id, faceIndex]: ", [result.entityType1, result.entityID1, result.faceIndex1]) print("Collision entity2 [type, id, faceIndex]: ", [result.entityType2, result.entityID2, result.faceIndex2]) print("Collision depth: ", result.depth) print("Collision direction: ", [result.directionX, result.directionY, result.directionZ]) model.hm_collisionend()
