Model.hm_proximitymarkcomponentallelementpairs#
Model.hm_proximitymarkcomponentallelementpairs(component_pair_index, collection1, collection2)#
Registers into collections the element pairs for a specific component pair.
This must be preceded by a call to Model.hm_proximityinit() and followed by a call to Model.hm_proximityend().
Parameters:
  • component_pair_index (unsigned int) – The index of the component pair. This starts from 0 and must be less that the value returned by Model.hm_proximitygetcomponentpaircount().
  • collection1 (Collection) – The output collection on which the element entities for the first component are placed.
  • collection2 (Collection) – The output collection on which the element entities for the second component are placed.
Returns:
Example#
Calculate the proximity between all components use a max distance of 2.5 and to query the component pairs#
import hm
import hm.entities as ent
model = hm.Model()
components_collection = hm.Collection(model, ent.Component)
model.hm_proximityinit(components_collection, max_distance=2.5)
_, result = model.hm_proximitygetcomponentpaircount()
comp_pair_count = result.numberOfPairs
i = 0
while i < comp_pair_count:
    _, result = model.hm_proximitygetcomponentpair(component_pair_index=i)
    comp_pair = result.entityPair
    print(f"Component pair {i}:", [c.id for c in comp_pair])
    elemFromComps1 = hm.Collection(model, ent.Element, populate=False)
    elemFromComps2 = hm.Collection(model, ent.Element, populate=False)
    model.hm_proximitymarkcomponentallelementpairs(
        component_pair_index=i, collection1=elemFromComps1, collection2=elemFromComps2
    print("Elements from 1st component:", [el.id for el in elemFromComps1])
    print("Elements from 2nd component:", [el.id for el in elemFromComps2])
    i += 1
model.hm_proximityend()
