Model.hm_getmoi#
Model.hm_getmoi(collection, location_flag=0, node_entity=Entity(), axes_flag=0, system_id=0, reserved_1=0, reserved_2=0, reserved_3=0, reserved_4=0, lumpedmassflag=0)#
Returns the tensorial moment-of-inertia Ixx, Iyy, Izz, Ixy, Ixz, Iyz values for the selected entities.
Parameters:
  • collection (Collection) – The collection containing the entities to query. Currently supported for components, elemements, materials, properties, parts, assemblies, plies, and laminates.
  • location_flag (int) –
    Specifies the location about which the MOI is calculated. Valid values are:
    0 - Global (0,0,0). Default.
    1 - COG location.
    2 - Node specified by node_entity argument.
    3 - System specified by system_id argument.
  • node_entity (Entity) – The object describing the node entity which specifies the node location about which the MOI is calculated if location_flag=2. Ignored otherwise..
  • axes_flag (int) –
    Specifies the axes to report the MOI values relative to. Valid values are:
    0 - Global axes. Default.
    1 - Principal axes
    2 - System specified by system_id argument.
  • system_id (int) – Specifies the system ID to report the MOI values relative to if axes_flag=2. Ignored otherwise.
  • reserved_1 (int) – Reserved for future use. Must be set to 0.
  • reserved_2 (int) – Reserved for future use. Must be set to 0.
  • reserved_3 (int) – Reserved for future use. Must be set to 0.
  • reserved_4 (int) – Reserved for future use. Must be set to 0.
  • lumpedmassflag (int) –
    Specifies whether to include lumped mass in the MOI calculations. Valid values are:
    0 - Exclude lumped mass.
    1 - Include lumped mass.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • moiValues (numpy.ndarray) - The tensorial moments of inertia (Ixx, Iyy, Izz, Ixy, Ixz, Iyz).
Example#
Get the MOI for components with IDs 1 - 5#
import hm
import hm.entities as ent
model = hm.Model()
component_collection = hm.Collection(model, ent.Component, list(range(1, 6)))
_, result = model.hm_getmoi(collection=component_collection)
print("MOI values:", result.moiValues)
