Model.stiffenedpanelmesh#
- Model.stiffenedpanelmesh(entity_type1, entity_type2, DeleteGeom, DestinationComp, BeamEntTypeU=0, BeamEntTypeV=0, BeamSecPropIDU=0, BeamSecPropIDV=0, BoundCurveU=0, BoundCurveV=0, CompName='', ElementID=0, ElementU=0, ElementV=0, LateralName='', LineCollection=Collection(), LongitudinalName='', NodeID=0, NoIntersectLineCollection=Collection(), ManifoldSurf=0, OriginPointID=0, PanelName='', ShellPropID=0, SurfaceCollection=Collection(), Tolerance=0.0, XDirPointID=0)#
Creates a stiffened panel mesh between lines or on surfaces.
- Parameters:
entity_type1 (EntityFullType) – Entity type which must be set to lines.
entity_type2 (EntityFullType) – Entity type which must be set to surfaces.
DeleteGeom (int) –
The option to keep or delete new geometries. Valid values are:
0 - Keep new geometries
1 - Delete new geometries
DestinationComp (int) –
The component organization. Valid values are:
0 - New component
1 - Current component
BeamEntTypeU (int) – The type of beam section or property assigned to the longitudinal beams created.
BeamEntTypeV (int) – The type of beam section or property assigned to the lateral beams created.
BeamSecPropIDU (int) – The ID of the type of beam section or property assigned to the longitudinal beams created.
BeamSecPropIDV (int) – The ID of the type of beam section or property assigned to the lateral beams created.
BoundCurveU (int) – The ID of the curve to specify the U direction. Renumbering will begin where it intersects the
BoundCurveV.BoundCurveV (int) – The ID of the curve to specify the V direction. Renumbering will begin where it intersects the
BoundCurveU.CompName (hwString) – The prefix name of the components to create for beams and shells.
ElementID (int) – The start ID for element numbering.
ElementU (int) – The number of shell elements in each panel in the U direction.
ElementV (int) – The number of shell elements in each panel in the V direction.
LateralName (hwString) – The name prefix of the components created for lateral beam elements.
LineCollection (Collection) – The collection containing the entities.
LongitudinalName (hwString) – The name prefix of the components created for longitudinal beam elements.
NodeID (int) – The start ID for node numbering.
NoIntersectLineCollection (Collection) – The collection containing the input line entities.
ManifoldSurf (int) –
The option to create mesh in the surfaces:
0 - Do not mesh surfaces
1 - Mesh surfaces
OriginPointID (int) – The ID of the origin point. The renumbering should begin from the origin point.
PanelName (hwString) – The prefix name of the components created for shell elements.
ShellPropID (int) – The ID of the shell property selected to assign on the shell elements created.
SurfaceCollection (Collection) – The collection containing the input surface entities.
Tolerance (double) – The tolerance for considering line intersections.
XDirPointID (int) – The ID of the direction point towards which the renumbering should propagate from the origin point.
Example#
Create stiffened panel mesh between selected lines#import hm import hm.entities as ent model = hm.Model() line_collection_1 = hm.Collection(model, ent.Line, [37, 39, 41, 43, 52]) line_collection_2 = hm.Collection(model, ent.Line, list(range(21, 26))) model.stiffenedpanelmesh( entity_type1=ent.Line, entity_type2=ent.Surface, LineCollection=line_collection_1, NoIntersectLineCollection=line_collection_2, SurfaceCollection=hm.Collection(model, ent.Surface, populate=False), DeleteGeom=1, DestinationComp=0, ElementID=2004, NodeID=1138, Tolerance=2.9149397464082, BoundCurveV=25, BoundCurveU=49, )
