Model.meshline_set_approximate_tol_factor#
Model.meshline_set_approximate_tol_factor(tol)#
Sets the tolerance factor for approximating meshlines with NURBs curves.
Parameters:
tol (double) – The tolerance factor to use. Must be > 0.0.
Example#
Set the meshline tolerance factor to 0.5#
import hm
import hm.entities as ent
model = hm.Model()
model.meshline_set_approximate_tol_factor(tol=0.5)
