Model.CE_ErrorSet#
Model.CE_ErrorSet(id, error_code)#
Assigns a pre-defined error to a connector.
Parameters:
  • id (unsigned int) – The ID of the connector.
  • error_code (unsigned int) –
    The error code to assign to the connector. Valid values are:
    0 - CE_ERROR_UNDEFINED
    1 - CE_ERROR_PROJECTIONS_LACKING
    2 - CE_ERROR_LINKS_UNRESOLVED
    3 - CE_ERROR_INCOMPLETE_REALIZATION
    4 - CE_ERROR_INCOMPATIBLE_FECONFIG
    5 - CE_ERROR_NO_TEST_POINT
    11 - CE_ERROR_LINK_LACKING_THICKNESS
    51 - CE_ERROR_AREA_LACKING_MESH
    61 - CE_ERROR_BOLT_HOLE_NOT_FOUND
    62 - CE_ERROR_BOLT_HOLE_LACKING
    63 - CE_ERROR_OVERLAP_1D_ELEM
    71 - CE_ERROR_MESH_IMPRINT_INCOMPLETE
    72 - CE_ERROR_MESH_IMPRINT_ACROSS_FEATURE
    73 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_ITSELF
    74 - CE_ERROR_MESH_IMPRINT_EXTREME_CASE
    75 - CE_ERROR_MESH_IMPRINT_MISSING_ELEMS
    76 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_OTHER
    77 - CE_ERROR_LESS_HEXA_HEIGHT
    78 - CE_ERROR_CUSTOM
    79 - CE_ERROR_MESH_IMPRINT_FAILED
    80 - CE_ERROR_NSM_PROPERTY_NOT_POSSIBLE
Example#
Assign error code 80 to connector with ID 10#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_ErrorSet(id=10, error_code=80)
