Model.align1delemsbysystem#
- Model.align1delemsbysystem(collection=Collection(), align='', angle=0.0, angledeviation=0.0, dimension='', system=0, xcomp=0.0, ycomp=0.0, zcomp=0.0)#
Aligns 1D elements with respect to global or local system.
- Parameters:
collection (Collection) – The collection containing the entities.
align (hwString) –
The axis of the system with respect to which the elements will be aligned. User can directly supply a Python string. Valid values are:
x or r - X axis
y or t - Y axis
z or p - Z axis
xy or rt - XY axis
yz or tp - YZ axis
xz or rp - XZ axis
all or xyz or rtz or rtp - All axes
vec - Uses vector components to define the alignment
angle (double) – The angular tolerance while aligning elements with respect to the axis of the input system.
angledeviation (double) – The angular tolerance to consider a particular axis for aligning.
dimension (hwString) – The dimension of the elements to consider. Valid value is 1D. User can directly supply a Python string.
system (int) – The reference system ID. If set to 0, the global system is used.
xcomp (double) – The x component of the vector when
align="vec".ycomp (double) – The y component of the vector when
align="vec".zcomp (double) – The z component of the vector when
align="vec".
Examples#
Align selected 1D elements with respect to local system with ID 1, along all its axes#import hm import hm.entities as ent model = hm.Model() elems = hm.Collection(model,ent.Element,[1,2,3,4]) model.align1delemsbysystem( collection=elems, dimension="1D", system=1, angle=15.0, align="xyz" )
Align selected 1D elements using vector components (1,0,0)#import hm import hm.entities as ent model = hm.Model() comps = hm.Collection(model,ent.Component,[1,2,3]) model.align1delemsbysystem( collection=elems, dimension="1D", angledeviation=15.0, align="vec", xcomp=1.0, ycomp=0.0, zcomp=0.0 )
