Model.combineelements#
Model.combineelements(collection, tolerance, angle)#
Combines the selected elements into one.
Parameters:
  • collection (Collection) – The collection containing the entities to be combined.
  • tolerance (double) – The maximum tolerance allowed before a node within the group of selected elements is considered to be not on the plane formed by any three nodes attached to the group of selected elements.
  • angle (double) – The maximum angle between three nodes which is considered to be a flat side.
Example#
Combine elements with IDs 10, 13, and 15 with an off plane tolerance of 0.1 and a flat angle of 150.0 degrees#
import hm
import hm.entities as ent
model = hm.Model()
model.combineelements(
    collection=hm.Collection(model, ent.Element, [10, 13, 15]),
    tolerance=0.1,
    angle=150.0,
Note
This function is obsolete and is provided only for backward compatibility
